Empty web interface
Bomberman
France
Empty web interface
Post by Bomberman »
Hello
I've had a problem with my NAS F2-423 for a few weeks. When I connect to my NAS via a web browser, I can't access anything. The connection to my NAS works (login and password) but the page that appears is empty. There are no menu icons.
My NAS works perfectly because I can access the file from Windows via TNAS PC.
My NAS is version 6.0.229. I can't update it because of the web interface problem.
Do you have a solution for me?
Re: Empty web interface
This could be a case of too many highly occupied programs being run, or some sort of unkown anomaly that is causing the lag.
May I ask what version of TOS you had before you updated to 6.0.229?
Are there any other devices using the same IP address?
Does trying to restart TNAS work?
If restarting TNAS doesn't help, you can try fixing it at the software level first by reinstalling TOS:
viewtopic.php?t=423
Please tell us the details and results of your attempt.
Bomberman
France
Post by Bomberman »
Hello
I shutdown the NAS via mobile app. After the restart, all work fine.
Thank you
Return to “Network”
