Small Notification of Processes Running in tos 6
carlosdesedas
Panama
Post by carlosdesedas »
Hi.. I'd like to suggest you guys implement a small notification dropdown los widget so that when a proceess is running on the NAS, you can see it... and by process, I mean something like running the SMART test on the disks... I clicked today to run the SMART process but there's nowhere on the seen, other than that specific window to let you know it's running... for example.. if I log out and log back in later, I'd like to easily be able to know if the SMART process is still running or not and with what % of completion...
Other than SMART process, another example is when copying files with the "File Explorer" of the NAS from one folder to another... sometimes this takes a long long time.. I'd like to know after I log out and back in if the copying process is still running...
Last example is the syncing process of a RAID 5 array.. I know you can see it by going into the Storage section... but it should show in a box as soon as I login the NAS.... so I don't have to go into the specific section to verify if it's running and at what %...
There are many other samples.... I'm sure you understand my idea... thanks!
Re: Small Notification of Processes Running in tos 6
The three processes you mentioned are all available to run in the background after you log out. There is already an icon related to “Copy” which can be seen as a dynamic icon on the right side of the TOS6 web page.
We'll talk about displaying the status of the other two processes.
carlosdesedas
Panama
thank you.. most importantly would be that if I log in an hour later, lets say.. and the process or processes are still running, I'd be able to see it without digging down in the menus... thank you again!
