Android TNAS Mobile 3 photo quality and backup issues
NasHodl
Austria
Post by NasHodl »
Hello, I have 2 major problems with this newly purchased NAS
1. Auto backup photos I select album e.g. /Media, but the backup is created in /Media/backup_name_Xiaomi/Camera.
- I want to be able to select my own path where it backs it up, is this possible? Just to the root of /Media?
2. The indexed photos when I click on a photo the quality is terrible. I have to click on "View original photo" before the quality is good. Can I just view all previews just with a good quality? Is there any settings at the moment to select "view preview in good quality" or something?
Would be a shame if these two simple things aren't possible.
BR,
NasHodl
Austria
Re: Android TNAS Mobile 3 photo quality and backup issues
Post by NasHodl »
PS. used:
TerraMaster F4-423 TOS 5
TNAS Mobile 3 Android
Regarding the backup path, it seems to be fine.
You can change the quality of the thumbnail in TOS > Control Panel > Media Index > Settings.
NasHodl
Austria
Post by NasHodl »
TMzethar wrote: 29 Jul 2024, 09:05 the backup path, it seems to be fine.
Thanks for the reply, I changed the quality now and it's not that bad anymore.
About the path, with another android app for syncing photos, I could also name the folder it creates standard e.g. I could rename "backup_android_phone" to "/Media" and sync this into the root / and it shows as "/Media/Camera/photo.jpg. This is what I also want to do in TNAS Mobile 3. This isn't possible?
NasHodl wrote: 29 Jul 2024, 15:21 About the path, with another android app for syncing photos, I could also name the folder it creates standard e.g. I could rename "backup_android_phone" to "/Media" and sync this into the root / and it shows as "/Media/Camera/photo.jpg. This is what I also want to do in TNAS Mobile 3. This isn't possible?
Custom backup path is not supported
