apps opening, but not on or off-screen?
Sketch15
Post by Sketch15 »
I'm running into a new issue. When i try to open an app, the app shows as open, but it does not appear on the screen. Its almost like its opening off-screen, but when I pan out, its still nowhere to be found. There is an odd tab that opens in the lower right corner, but disappears as soon as I click on it. I haven't made any changes - though I can't rule out any auto-updates.
Does anyone have any ideas? Image attached.
TMtina
Re: apps opening, but not on or off-screen?
Post by TMtina »
Are you accessing via TNAS.online or LAN? Try refreshing the browser.
