Replicate all data to new storage pool
Tony92
Post by Tony92 »
I am new to NAS. I have a F4-424. Storage Pool 1 is a RAID 0 with a 18TB and 4TB. I recently added two more 18TB drives and set up Storage Pool 2 as TRAID.
What's the best method to migrate all data - especially applications and docker stuff, over to Storage Pool 2 (Volume 2) so I may eventually format and delete Storage Pool 1 and have it can be combined with the TRAID storage? :?:
Thanks!
F4-424 Pro: 4Bay Core i3-N305 8-Core 8-Thread CPU, 32GB DDR5 RAM | TRAID Pool 1 (18TBx18TBx18TBx4TB SATA HDDs) | TRAID Pool 2 (Two Samsung 980 NVMe M.2 1TB/ea)
D8 Hybrid attached: Single Disk (12TB SATA HDD)
Re: Replicate all data to new storage pool
There is no good way to accomplish this yet.
TMzethar wrote: 18 Jul 2024, 09:24
So what is the purpose of Shared Folder -> more -> Advanced -> Restore to [Vol1|Vol2|Vol3]
Curious as it never seems to do anything positive.
Tony92
Post by Tony92 »
Wasn’t overly concerned about shared folders. I can copy/move thoughts. But the apps and their settings I needed to do an exact copy or move from one volume to a new one and wanted to ensure I did it properly. Looks like I’ll have to just start over which sucks
Gremlin wrote: 18 Jul 2024, 21:38 So what is the purpose of Shared Folder -> more -> Advanced -> Restore to [Vol1|Vol2|Vol3]
Its main function is as stated: "After the system is updated, or after the volume is remounted, some shared folders may fail to be mounted and cannot be displayed. operation will restore the shared folders that have failed to mount, and the normally displayed folders will not be affected."
Alternatively, it can be used to change a system-dependent volume to a different one, after which the public and user directories will read and write on the new volume and the public and user directories of the previous volume will no longer be displayed.
bconnor218
Post by bconnor218 »
TMzethar wrote: 19 Jul 2024, 10:53
Would you mind explaining what this does in more detail? I'm not fully understanding what this setting accomplishes.
