DLNA File Compatibility
echemh
Post by echemh »
I am trying to watch some of my videos using the DLNA through my SmartTV and my PS4. Both have same issue. I go to watch some of my videos and thy it gives me there is no playable media message in some folders I know have videos there. How do I fix this?
Re: DLNA File Compatibility
Your smart TV and PS4 does not support such video type playback. You could use media server like Plex or Emby to transcode such un-supported video type. By the way, what is your TNAS model number?
echemh
Post by echemh »
Model # F4-210. I understand because apparently some videos are playable on my SmartTV that won't play on PS4.
Yeah, PS4 can only play a few video codecs, you better play with other device.
Tricky
Post by Tricky »
Not sure if the F4-210 is capable of trans-coding on the fly but that what you need try Plex as i believe that does.
echemh
Post by echemh »
I tried Plex pass and it not compatible with this model. I tried Emby and could not get it to work.
Tricky
Post by Tricky »
Then I'm afraid that you stuck with what the device your trying to play the files on can decode you need the 221 in order to transcode on the fly.
