VPAN Server Tailscale
An application set your TNAS as a VPN server
MordaniMeillis
Post by MordaniMeillis »
I have a Terramaster F4-210 NAS. I need to access it remotely, just as if it were from my local network. To do this, I understand that I need to install a VPN. Given the complexity of this, I have found that it is much easier to use the Tailscale service. How could I do it?
Additionally, I have a problem that consists of the malfunction and use of external hard drives in the USB 3.0 connections that exist on my NAS. Could you tell me how to solve this?
Thank you so much.
All the best.
Re: VPAN Server Tailscale
Hi, VPN is not supported on F4-210(either as a server or as a client).
TJ27sk
Post by TJ27sk »
You may be able to install a 3rd party app (presuming that is the correct app for your system architecture) but that does not mean that TM will support it. You would need to approach the community that wrote the application for support.
Frustrated Beta Tester!!!
Return to “VPN Server”
