Just started to surface test hdd's (which were Traid config) so that will be a while
Been here: viewtopic.php?p=29456&hilit=boot+loop#p29456
but don't see much else on the forum of a similar vein. I will check the power supply though at some point.
During a normal system startup process, the hard drive should not have a red light on. There is likely a hardware failure in your device, possibly with the motherboard, power adapter, or even the hard drive. Please check each one to identify the issue.
Yes, you can boot from the previous HDD in the new device, and you have to set in BIOS boot from HDD.
Here's a breakdown of what these messages mean:Gremlin wrote: ↑20 Jul 2024, 21:17 OK, so old F2-221 left for dead (for now anyway)
Set up a new F2-424 (standard, no 'extras') and checked boot into bios = OK. Just changed Bios date.
Set up old Tos 6.0 disks (Traid) and booted.
Everything appears OK except previously unseen error message(s)
BTRFS error (device dm-0): parent transid verify failed on logical ........ mirror {1,2} wanted 8966 found 8933 [2 messages total]
BTRFS error (device dm-0) failed to run delayed ref for logical .......... mum_bytes 65536 type 176 action 1 ref_mod 1: -5
BTRFS: error (device dm-0: State A) in BTRFS_run_delayed_refserror=-5 IO failure
BTRFS info (device dm-0:) State EA: forced read only
BTRFS error (device dm-0: State EA): parent transid verify failed on logical ........ mirror {1,2} wanted 8966 found 8933 [2 messages total]
Should I be concerned about these messasges? Nothing apparent in control panel. Should these clear on reboot? I am happy to re-install system if that is needed.
