Partition Access Media
DragonServ
Brazil
Post by DragonServ »
My Terra do nowhere keeps making a noise and it's not from the HD it doesn't start I already put the disk directly in my pc it detects everything normal. I would like to know which system I can access the HD because I have 6tb of documents and I don't want to lose it I was transferring from my PC to the new 16tb disk that I bought recently and it out of nowhere stopped starting and giving a reading and then it kind of vibrates I thought it was the HD but it's not it. how do i get access to the files from the other partition being ext4???
Model F4-424 Pro
DragonServ
Brazil
Re: Partition Access Media
feedback, when you put the system in hebernation mode disabled the HD system and everything else that exists in the Terra Master is in a loop.
Do an update to fix this because I had to lose my files to find this problem.
You can map the shared folders of the NAS to the PC and then transfer the data on the PC.
https://help.terra-master.com/TOS5/view ... le_service
Hibernation will generally only hibernate the HDD, if your storage configuration is just set up, RAID synchronization or volume initialization will need to run for a while, during which time your HDD can not be hibernated. In addition, these factors may also affect HDD hibernation.
viewtopic.php?t=473
