How to install NextCloud  [SOLVED]
Discussion about Docker
SquarePeg
Wales
Post by SquarePeg »
Hi
I am trying to install Nextcloud to backup my photos etc but everytime I try to install via Docker, the container fails. Could someone please guide me through how to install Nextcloud on my NAS?
matteoar1
Italy
Re: How to install NextCloud
Post by matteoar1 »
Same here, I really don't understand how docker works.
In order for us and other forum users to better understand the issue, please provide at least the TNAS model, TOS version, Docker application version, and other relevant key information.
SquarePeg
Wales
Post by SquarePeg »
I am using a F5-422, running TOS 5.1.131-00123. The docker application I have tried to use is this https://hub.docker.com/r/linuxserver/nextcloud
TMLeeh
Post by TMLeeh »
Please carefully check the configuration of the startup container to ensure that all settings are correct.
TNguyen
France
Post by TNguyen »
Do you succeed to install Nextcloud ?
makhai
France
Post by makhai »
SquarePeg wrote: ↑06 Jul 2024, 00:50
matteoar1 wrote: ↑02 Aug 2024, 17:58
Is your problem solved ?
SquarePeg
Wales
Post by SquarePeg »
TNguyen wrote: ↑10 Aug 2024, 23:20 Do you succeed to install Nextcloud ?
Nope, still not got it to work
makhai
France
Post by makhai »
SquarePeg wrote: ↑23 Aug 2024, 23:48
Can you show us your yml config file ?
SquarePeg
Wales
Post by SquarePeg »
makhai wrote: ↑23 Aug 2024, 23:49
I've removed docker and given up
Return to “Docker”
