[TOS6] Login timeout bug?
Sparker
Post by Sparker »
I am not sure where to post TOS6 bugs, I can submit to the correct place if required.
I upgraded my F4-424 Pro from 5.0.131 to 6 today, and in 5 I was not auto logged out after 5 mins (if when logging in "keep me logged in" is checked), but this does happen in 6. The only workaround I could find is in General Settings > Security > Enable TOS automatic logout on timeout (leave checked) and then set to 1440 minutes. If I uncheck that setting I am logged out after 5 minutes.
But the bug I am reporting is that on the login screen "keep me logged in" does not work, and also unchecking "Enable TOS automatic logout on timeout" seems to be ignored.
EthanLiu
Re: [TOS6] Login timeout bug?
Post by EthanLiu »
Sparker wrote: ↑05 Jul 2024, 21:39
Hello, in TOS version 5.1.131, if you choose not to tick the "Automatic Logout on Timeout" feature, the system will automatically follow the default 5-minute timeout logout rule. Additionally, the setting of "Automatic Logout on Timeout" has a higher priority than the "Stay Logged In" option. For your convenience, we recommend enabling the "Automatic Logout on Timeout" feature and setting a more reasonable and extended time interval based on your personal needs.
