nginx - Containers
Transmission, qBittorrent, Aria 2 download applications
rojsan
France
nginx - Containers
Post by rojsan »
Hi Everyone,
It's my first server setup, knew knothing about unix a month ago, and to say the least the learning curve has been steep.
I have setup anm arr suite on portainer successfuly, and to finalise all that I'm trying to setup a reverse proxy (nginx). and it turns out to be the hardest step.
I had multiple install on container, that i removed, nevertherless. the service nginx is still running. and from now on I can't install nginx on portrainer (error 500).
I tried to remove the nginx service but can't access my TOS anymore... anyway I'm in a pickle as there is a lot of services running.
Fluff 2662 0.0 0.0 390360 3176 ? Ss 09:40 0:00 php-fpm: master process (/etc/nginx/php-fpm.conf)
Fluff 3004 0.0 0.0 66664 1676 ? Ss 17:16 0:00 nginx: master process /usr/sbin/nginx -p /var/ -c /etc/nginx/nginx.conf
Fluff 3005 0.0 0.2 73276 8228 ? S 17:16 0:00 nginx: worker process
Fluff 3006 0.0 0.1 73212 7496 ? S 17:16 0:00 nginx: worker process
Fluff 3007 0.0 0.1 73116 5356 ? S 17:16 0:00 nginx: worker process
Fluff 3008 0.0 0.2 73312 8224 ? S 17:16 0:00 nginx: worker process
Fluff 15859 0.0 0.0 3120 244 pts/0 D+ 17:26 0:00 grep nginx
[Fluff@Bean ~]# pidof nginx
3008 3007 3006 3005 3004
I'm a bit lost on how these services are still on even though I deleted the containers...
Would anyone have an idea, on how to start on a clean slate ?
Thanks !
tommi2day
Germany
Re: nginx - Containers
Post by tommi2day »
this nginx is part of TOS, dont touch it.
You may add your own nginx using docker/portainer, but you have to use different ports
if you dont touched the config files in /etc/nginx you can try to reboot or, if you had enabled access via ssh, then you may try to start the system nginx with "service nginx start
main: T9-450
Return to “Download”
