Best solution for photo backup and how to install?
SquarePeg
Wales
Post by SquarePeg »
Hi all
I have recently installed TOS5 and I am trying to find an alternative to Google Photos. Can anyone recommend a good application and also how to install? I have tried to install NextCloud via Docker but the container keeps failing when I try to launch it.
Can someone help please?
Re: Best solution for photo backup and how to install?
You can install Terra Photo on your TNAS, and install TNAS mobile app on your mobile phone.
SquarePeg
Wales
Post by SquarePeg »
How exactly? I've been trying to find it in the applications but it isn't there
SquarePeg
Wales
Post by SquarePeg »
Added the wrong attachment and couldn't edit the post
What version of TOS5 are you using?
Terra Photo can only be obtained on higher TOS5 versions now.
Perhaps you can try clearing the browser cache or updating to the latest TOS 5.1.131:
viewtopic.php?t=6124
Observing that you are using the TNAS model from the TOS4 period, if you want to update to TOS 5.1.131, please determine if it meets the conditions for updating to change the TOS5 version:viewtopic.php?t=4912
codykuphal
Post by codykuphal »
PhotoPrism is a high-quality, sharp photo backup application. The steps to install PhotoPrism include: installing Docker, creating a storage directory, running the container, and accessing it via a browser. Hope you have a successful installation.
pixelspusher
Post by pixelspusher »
I actually wrote a quick guide to get you setup with Immich, which is a Google Photos clone and my personal favourite solution. You can check it out here: https://github.com/lucasengel/tos-guides
SquarePeg
Wales
Post by SquarePeg »
Hi, thanks for the guide, I'm getting an error when trying to validate:
My YAML file looks like this:
# WARNING: Make sure to use the docker-compose.yml of the current release:
# https://github.com/immich-app/immich/releases/latest/download/docker-compose.yml
# The compose file on main may not be compatible with the latest release.
services:
  immich-server:
    container_name: immich_server
    image: ghcr.io/immich-app/immich-server:${IMMICH_VERSION:-release}
    # extends:
    #   file: hwaccel.transcoding.yml
    #   service: cpu # set to one of [nvenc, quicksync, rkmpp, vaapi, vaapi-wsl] for accelerated transcoding
    volumes:
      # Do not edit the next line. If you want to change the media storage location on your system, edit the value of UPLOAD_LOCATION in the .env file
      - ${UPLOAD_LOCATION}:/usr/src/app/upload
      - /etc/localtime:/etc/localtime:ro
    env_file:
      - .env
    ports:
      - '2283:2283'
    depends_on:
      - redis
      - database
    restart: always
    healthcheck:
      disable: false
  immich-machine-learning:
    container_name: immich_machine_learning
    # For hardware acceleration, add one of -[armnn, cuda, openvino] to the image tag.
    # Example tag: ${IMMICH_VERSION:-release}-cuda
    image: ghcr.io/immich-app/immich-machine-learning:${IMMICH_VERSION:-release}
    # extends: # uncomment this section for hardware acceleration - see https://immich.app/docs/features/ml-hardware-acceleration
    #   file: hwaccel.ml.yml
    #   service: cpu # set to one of [armnn, cuda, openvino, openvino-wsl] for accelerated inference - use the `-wsl` version for WSL2 where applicable
    volumes:
      - model-cache:/cache
    env_file:
      - .env
    restart: always
    healthcheck:
      disable: false
  redis:
    container_name: immich_redis
    image: docker.io/redis:6.2-alpine@sha256:2ba50e1ac3a0ea17b736ce9db2b0a9f6f8b85d4c27d5f5accc6a416d8f42c6d5
    healthcheck:
      test: redis-cli ping || exit 1
    restart: always
  database:
    container_name: immich_postgres
    image: docker.io/tensorchord/pgvecto-rs:pg14-v0.2.0@sha256:90724186f0a3517cf6914295b5ab410db9ce23190a2d9d0b9dd6463e3fa298f0
    environment:
      POSTGRES_PASSWORD: ${DB_PASSWORD}
      POSTGRES_USER: ${DB_USERNAME}
      POSTGRES_DB: ${DB_DATABASE_NAME}
      POSTGRES_INITDB_ARGS: '--data-checksums'
    volumes:
      # Do not edit the next line. If you want to change the database storage location on your system, edit the value of DB_DATA_LOCATION in the .env file
      - ${DB_DATA_LOCATION}:/var/lib/postgresql/data
    healthcheck:
      test: pg_isready --dbname='${DB_DATABASE_NAME}' --username='${DB_USERNAME}' || exit 1; Chksum="$$(psql --dbname='${DB_DATABASE_NAME}' --username='${DB_USERNAME}' --tuples-only --no-align --command='SELECT COALESCE(SUM(checksum_failures), 0) FROM pg_stat_database')"; echo "checksum failure count is $$Chksum"; [ "$$Chksum" = '0' ] || exit 1
      interval: 5m
      #start_interval: 30s
      start_period: 5m
    command:
        'postgres',
        '-c',
        'shared_preload_libraries=vectors.so',
        '-c',
        'search_path="$$user", public, vectors',
        '-c',
        'logging_collector=on',
        '-c',
        'max_wal_size=2GB',
        '-c',
        'shared_buffers=512MB',
        '-c',
        'wal_compression=on',
    restart: always
volumes:
  model-cache:
Mamex
Italy
Post by Mamex »
pixelspusher wrote: ↑21 Oct 2024, 00:52 I actually wrote a quick guide to get you setup with Immich, which is a Google Photos clone and my personal favourite solution. You can check it out here: https://github.com/lucasengel/tos-guides
Thanks for your guide I managed to create the project but it's been in Building for a while is that normal?
TMeric
Post by TMeric »
Why not give our Terra Photos a try? It's more convenient to install and use, and we will be rolling out a major upgrade to the AI facial recognition feature in the upcoming version. Stay tuned!
Return to “Others”
