Transcoder temporary directory
deliciousT90
Spain
Post by deliciousT90 »
Can i set Transcoder temporary directory in /dev/shm to use ram for it?
I have a lot of ram without use (F4-424 Pro)
IrisLi
Re: Transcoder temporary directory
Post by IrisLi »
Yes, you can set the temporary directory for a transcoder to /dev/shm to utilize RAM as a temporary storage area.
However, there are a few things you should be aware of:
Limited Space: RAM is a limited resource, so /dev/shm (or any tmpfs) will have a size limit based on the available RAM. Make sure the transcoding process does not try to write more data to the RAM than is available.
Persistence: Data stored in /dev/shm is lost when the system reboots or the tmpfs is remounted
Return to “Plex Media Server”
