A low-power mode for DAS Eclosures
mjaafar
Post by mjaafar »
The ability for the enclosure to go into sleep mode, turning off the fan, when not in use, and not just when the PC is off
I have the D4-320 and because of the proximaty of the enclosure, the fan is not as silent as I would like it to be.
So I would gratly like a way to make the unit go to sleep while my PC is still on and wake up only when I need it to do something.
Re: A low-power mode for DAS Eclosures
The D4-320 has this feature where it will go into sleep mode when your computer is not in use. This sleep mode is synchronized with the system's sleep.
mjaafar
Post by mjaafar »
I know, but I would like it to go into sleep mode when the computer is in use
for instance if there's no activity within the drives of the enclosure or the temperature is low enough the fan isn't needed to cool the drives
you see, I don't access the enclosure drives all the time, and I have to manually turn off the enclosure because of the constant fan noise, while that is a solution, having to do that each time, becomes tedious after a while.
mjaafar wrote: 09 Jun 2024, 16:15
The function you need is not supported temporarily.
