Yandex task confirmation fails
MagicPhotoEvents
France
Post by MagicPhotoEvents »
I have added a Yandex Disk connection with success but the task creation fails.
I create a new task using the yandex connection.
On the second step, I choose a name for the task, the local and cloud directories, and the synchronization mode then I go to the next step.
On the third step, nothing special.
On the fourth step, there's the summary of the parameters and two buttons, one for going back and another to confirm.
When I clic to confirm an error message appears : "The local directory is not available. Please select another directory."
I am on TOS 5.1.131 and use CloudSync 3.1.1
Thanks for your help
F5-221 TOS 5.1.131, 3 x 4TB RAID5
EthanLiu
Re: Yandex task confirmation fails
Post by EthanLiu »
MagicPhotoEvents wrote: 07 Jun 2024, 00:52
The current version only supports one synchronization task for one folder, and it is temporarily unable to assign multiple synchronization tasks to a single folder. You can try using a different local directory instead.
MagicPhotoEvents
France
Thank you so much !!!
Return to “CloudSync”
