Docker hub doesn't work
Discussion about Docker
baf28
Post by baf28 »
Hello.
The problem was hired on 30.05.2024. Docher Hub stopped working.
TerraMaster F2-223 5.1.131 device
In the settings, I added a mirror that works on my Ubuntu Linux, but it didn't work in TerraMaster.
https://mirror.gcr.io
https://dockerhub.timeweb.cloud
Tell me if the mirror doesn't work, is it a bug or how can I fix it?
Re: Docker hub doesn't work
Can you see the list of mirrors in the default configuration before you make any changes?
We will verify what you describe.
baf28
Post by baf28 »
Before the changes, this did not work, as the docker hub blocked access. So I added mirrors, as I did on Synology. But it didn't work in terramaster.
IdiotBox
Post by IdiotBox »
TOS6 .229 Similar problem.
DCCentR
Post by DCCentR »
Same for me on TOS 6.0.229. After adding other registries as mirrors or as the main address, the Registry page still blank.
Tried adding these: https://dockerhub.timeweb.cloud, https://mirror.gcr.io, https://ghcr.io.
https://hub.docker.com/ now blocked in Russia since May 31.
F4-424 Pro
XFNeo
Post by XFNeo »
TMzethar wrote: 01 Jun 2024, 17:23
Hi! The same question how to make registry-mirrors work?
samius
Post by samius »
you can try use a proxy
https://huecker.io/
F4-424 MAX TOS 7
baf28
Post by baf28 »
samius wrote: 02 Jun 2024, 06:58 you can try use a proxy
https://huecker.io/
It's a very bad idea, because then all applications and DDNS will work through it's not clear which and whose proxy.
XFNeo
Post by XFNeo »
Proxy is also not working in daemon.json
I tried to add
  "proxies": {
    "http-proxy": "socks5://95.217.168.125:1080",
    "https-proxy": "socks5://95.217.168.125:1080",
    "no-proxy": "*.test.example.com,.example.org,127.0.0.0/8"
to /Volume1/@apps/DockerEngine/conf/daemon.json and nothing.
XFNeo
Post by XFNeo »
[user@TNAS-MATI ~]# cat /Volume1/@apps/DockerEngine/conf/daemon.json
  "registry-mirrors": [
    "https://mirror.gcr.io"
  "proxies": {
  "log-driver": "json-file",
  "data-root": "/Volume1/@DockerData",
  "pidfile": "/var/run/docker.pid",
  "live-restore": true,
  "bip": "172.17.0.1/16"
[user@TNAS-MATI ~]# service docker restart
[user@TNAS-MATI ~]# docker pull koenkk/zigbee2mqtt:1.38
Error response from daemon: error parsing HTTP 403 response body: invalid character '<' looking for beginning of value: "<html><body><h1>403 Forbidden</h1>\nSince Docker is a US company, we must comply with US export control regulations. In an effort to comply with these, we now block all IP addresses that are located in Cuba, Iran, North Korea, Republic of Crimea, Sudan, and Syria. If you are not in one of these cities, countries, or regions and are blocked, please reach out to https://hub.docker.com/support/contact/\n</body></html>\n"
Return to “Docker”
