F5-221 and BIOS version
Notred
Post by Notred »
I have two F5-221, updated to 5.1.131 but the BIOS version is totally different.
5.12 for one and MAPL0304V17 for the other.
Any body know the reason for this ?
Is it a problem somehow ?
If yes, how should I proceed to correct this ?
Thanks !
Re: F5-221 and BIOS version
This may be due to the inconsistency of the version used at different times of production, which does not affect your use.
If you want the two to display the same, you need to update the BIOS version yourself, if you need to update, you need to email our technical support team to get the corresponding firmware.
Notred
Post by Notred »
Thanks for the answer. Well I dont "need" to update but if one of the 2 version is presenting some serious bugs or flaws, well I'd rather to do ti.
Which one if the latest one and is there any release note to peruse ?
BIOS v5.1.2 is an earlier version and no upgrades are available.
BIOS MAPL0304V17 is a later version and you have the option to update the BIOS if needed.
