Does anyone know how to fix this error message I get on docker on my NAS.
NAS info
Model
F5-221
TOS version
5.1.67-00214
Docker error
Docker error
- Attachments
- Here’s a screenshot of the error message.
- IMG_7599.png (17.48 KiB) Viewed 650 times
Re: Docker error
Please check if the system time is correct on your TNAS. Or update your TOS to the latest version.
By the way, do not duplicate your posts with the same issues.
Re: Docker error
Sorry for the duplicate but it didn’t seem to get any response at the end of the last one so I started a new one. Sorry didn’t realize that as against the rules. I really want to get this fixed as soon as possible thank you.
Anyway the time is set right as of my county time zone. And it is staying that it is updated to the latest software.
Re: Docker error
Please contact our customer service through the Terramaster official website to arrange for remote assistance. Please send a screenshot of this page to the customer service personnel during the communication.
Re: Docker error
Never received any other similar feedback. Depending on your TNAS model and TOS version.
It's possible that incomplete updates or smaller system partitions are affecting it, and it's hard to tell the exact process that's affecting it.
You may consider referring to this to try to solve it:
viewtopic.php?t=4912
Re: Docker error
How can it be a update error if its saying that the software is up to date and docker was working a month or 2 ago fine for me. I have changed nothing and my Network is fine as far as I can tell because everything else on my was is working just as it was.
Is there anything else this could be ?
Re: Docker error
Have you actually verified the size of your system partition? It's not that difficult.
Regardless of what you may think, 5.1.67 is not the most up to date version of Tos5.1. But, there may be (?good?) reasons for the system indicating it is up-to-date. My F5-221is currently running 5.1.123 (112 days uptime) and there is another later version I have yet to try.
Re: Docker error
You can try the following link to check the system's update requirements.
TOS 5.1.131 (X86) is Released for Update
Re: Docker error
Control Panel > System Info > Overview
- Resource - "/" displays {Used / Total} size of available system partition.
