Is there a way to control D5-300 spin down?
mediaguru
Greece
Post by mediaguru »
I have 4 of the 5 slots filled in my D5-300, directly connected to my Mac M1 Pro Max laptop. Whether or not I'm accessing the drives, they spin down constantly. Then when I need to access something, my whole system is on hold while all four drives spin back up. Is there a way of making the sleep time longer? Also, the drives spin up and spin down even when the laptop is in sleep mode.
Thanks for any help you may be able to provide.
Re: Is there a way to control D5-300 spin down?
The spin-up or spin-down of D5-300 depends on the signal your computer provides. You can try to modify the relevant settings about battery or power supply in the settings of Mac.
Olli2024
Germany
Post by Olli2024 »
On linux there is a package called hdparm to manage energy management and spindown better on USB hard drives with works pretty well.
Since the Mac OS is based on unix I am pretty sure there are similar (homebrew) project to setup power management like this too.
Sorry I can not give better examples for a Mac.
mediaguru
Greece
Post by mediaguru »
Came back after a 1+ years to see if there's any other solution? In the mac system settings I've set the sleep to never, but they still spin down constantly. Should I instead of hooking it directly via usb-c, set it up on my network? also, I don't think there's a compatible management software for a mac m4 on Sequoia, is there?
Return to “USB Series”
