32-bit only?
datahorder
32-bit only?
Post by datahorder »
I only see the ability to use 32-bit operating systems on Virtual Box. But my NAS has an Intel® Celeron® J3455,
and its Processor Architecture is X.86 64-bit.
How can I allow for 64-bit OSs to be installed?
Re: 32-bit only?
Please be noted that all X86 models including 220/221/421/422 are supporting VirtualBox. Only 210 model does not support VirtualBox at the moment.
Re: 32-bit only?
datahorder wrote: ↑07 Jul 2020, 12:08 I only see the ability to use 32-bit operating systems on Virtual Box. But my NAS has an Intel® Celeron® J3455,
As the VT-x feature has not been activated in previous models. To install a 64 bit OS in your VirtualBox, you need to enable this feature, here is what you need to do viewtopic.php?f=75&t=545
datahorder
Re: 32-bit only?
I'm using an F2-421.
I got the 64-bit OS options to show up using those steps. You also need to enable (for Intel x64):
VT-x (Intel Virtualization Technology) as well as VT-d.
But when I tried to create a new virtual disk it says:
In the details it says:
Exception Object
[message:protected] => Could not create the medium storage unit '/home/VBox/Ubuntu1804/Ubuntu1804.vdi'.
VDI: disk would overflow creating image '/home/VBox/Ubuntu1804/Ubuntu1804.vdi' (VERR_DISK_FULL).
VDI: setting image size failed for '/home/VBox/Ubuntu1804/Ubuntu1804.vdi' (VERR_DISK_FULL)
[string:Exception:private] =>
[code:protected] => 0
[file:protected] => /mnt/md0/application/share/virtualbox/vbox/endpoints/lib/vboxconnector.php
[line:protected] => 5129
[trace:Exception:private] => Array
[0] => Array
[file] => /mnt/md0/application/share/virtualbox/vbox/endpoints/lib/vboxconnector.php
[line] => 951
[function] => remote_mediumCreateBaseStorage
[class] => vboxconnector
[type] => ->
[args] => Array
[0] => Array
[file] => /home/VBox/Ubuntu1804/Ubuntu1804.vdi
[type] => fixed
[size] => 10240
[format] => VDI
[split] =>
[1] => Array
[file] => /mnt/md0/application/share/virtualbox/vbox/endpoints/api.php
[line] => 316
[function] => __call
[type] => ->
[args] => Array
[0] => mediumCreateBaseStorage
[1] => Array
[0] => Array
[type] => fixed
[size] => 10240
[format] => VDI
[split] =>
[1] => Array
[0] => Array
[data] => Array
[responseData] =>
[success] =>
[key] => 53474945cfd7ac0bf8114767c209c2a6
[errors] => Array
[persist] => Array
[messages] => Array
[previous:Exception:private] =>
My disk isn't full, there's lots of space free.
datahorder
Re: 32-bit only?
Any insight into why I'm getting that error message?
macmpi
Re: 32-bit only?
Post by macmpi »
Are you on btrfs?
I remember reading about some Virtualbox issues wrt btrfs...
Re: 32-bit only?
Is the former disk deleted yet?
datahorder
Re: 32-bit only?
Yeah, I'm using the default file system, btrfs
What's the 'former disk'? and how do I delete it?
Return to “Virtual Machines”
