Not sure what happened but after the last install of TNAS 5.1, the Stay Logged In check box stopped working. It used to work, but now I get kicked off WAY too quickly. If you're going to offer the paid user a convenience, it should actually work.
The Don't Prompt Me Again check box STILL doesn't work in the Tips window either. I check it every time and every time I log in again and open the file folder it's there. I'll say it again - if you're going to offer the paid user a convenience, it should actually work.
New feature I want - for the Stay Logged In check box to actually work
Re: New feature I want - for the Stay Logged In check box to actually work
The system has activated the default automatic logout feature, with a 5-minute timeout. If there is no activity within this period,the system will log out automatically,disabing the stay logged-in function. Adjust the timeout duration or disable automatic logout to retain the stay logged-in option. Be aware that altering these settings may pose security risk,so understand and evaluate these risks before making any changes.
If still be automatically logout, you can try to update the TOS:viewtopic.php?t=6155
If you need to change the logout time, you can go to the security module of the control panel and set a longer timeout.
