Change the SMB service configuration
Graemezee
Post by Graemezee »
Mac user Wants to Use Carbon Copy Cloner by Bombitch to back up files it's a mac version of Rsync
I know backing mac files Some NAS services have obtuse file name restrictions and will create issues, they suggest
Change the SMB service configuration on the NAS
If your NAS device allows changes to its SMB configuration, you can add "mangled names = no" to the end of its smb.conf file to disable SMB name mangling
Append the smb.conf file:
sudo -s
echo "mangled names = no" >> /etc/samba/smb.conf
Is this still relevant do I need to make these amends or should I Use AFP Shares instead?
Re: Change the SMB service configuration
I think you may be able to add addition configuration options in the 'advanced' section of SMB config. (Obviously, "suck it and see")
Frustrated Beta Tester!!!
Return to “File Services”
