Data scrubbing on TRAID pool
- DigitalAnalog
Hi - I just noticed that I can't access the More menu in the Storage Pool section and thus can't utilise the Data scrubbing function. I have the relevant pool selected but the More menu (...) is grayed out. Any thoughts?
F4-423
- DigitalAnalog
Re: Data scrubbing on TRAID pool
To add - filesystem is btrfs running the latest TOS 5 on an F4-423.
F4-423
Thanks for raising this. It is not just the latest TOS5.1 version.
Frustrated Beta Tester!!!
TRAID does not currently support the Data Scrubbing.
It used to, didn't it?
- DigitalAnalog
Yes, and as recently as an hour or so ago it seems judging by TM's edited reply.
Data scrubbing is a btrfs feature that's supported even with flexible RAIDs like Synology SHR.
F4-423
