cloudsync not working
oscar1412
Spain
Post by oscar1412 »
The cloudsync does not work, it stops and indicates synchronizing and it takes more than 2 hours and does nothing.
number of files transferred when setting it to 3 or 4 or any data starts uploading files after 1 min it stops
TMeric
Re: cloudsync not working
Post by TMeric »
Please try to reconnect to your cloud server and re-create the synchronization task to see if it works properly?
oscar1412
Spain
Post by oscar1412 »
I already did it and it's still the same, it starts and after a while it stops.
TMtina
Post by TMtina »
oscar1412 wrote: 06 May 2024, 22:33
Please contact the customer service on the official website to schedule an engineer to check it remotely for you.
oscar1412
Spain
Post by oscar1412 »
It's a shame, why would they launch cough 6?, otherwise half of the app works, cloud sync hasn't worked for months. I'm going to file a consumer complaint, as it's possible that the technical service is a disaster.
EthanLiu
Post by EthanLiu »
oscar1412 wrote: 07 May 2024, 11:01
Hello, which version of the CloudSync app are you using? What is the TOS system version? Which cloud storage service are you connecting to during the use of the CloudSync app? What is the approximate size of the files being synchronized?
oscar1412
Spain
Post by oscar1412 »
I contacted support and the engineer couldn't do anything, a disaster, cloudsync doesn't work, the cloud provider had it with opendrive it doesn't work now with box.com it doesn't work either and files that are more than 20 gigabytes in capacity, and they only upload 365 bytes, the rest nothing, cloudsync 3.1.1 and cough 6.0.229.
I do not know what to do
EthanLiu
Post by EthanLiu »
oscar1412 wrote: 19 May 2024, 03:48
Hello, which service did you subscribe to? Is it Personal or Basic?
oscar1412
Spain
Post by oscar1412 »
personal box.com
It doesn't work, it only uploads 512kbyte files, the rest don't upload them
EthanLiu
Post by EthanLiu »
oscar1412 wrote: 16 Jun 2024, 20:29
When you encounter a situation where the backup file is large, due to the vast amount of data, the synchronization process may take relatively longer, and therefore, the progress updates may not be as prompt. Please be patient during this time, as we understand this may cause some inconvenience to you. At the same time, we have taken note of your description and will conduct an in-depth analysis based on your actual situation to better assist you in resolving the issue. Before that, to troubleshoot potential application issues, you may consider uninstalling the application completely and reinstalling it.
Return to “CloudSync”
