Hi
I recently needed to modify the terramaster static IP and changed it with tnas app (latest) from 192.168.1.219 to 192.168.1.22; no IP conflict on tne lan of course
Now I’ve lost access: the NAS starts and leds’re ok but whatever IP I use I can’t get access to the NAS
Finally I wanted to reset but I didn’t find any description or reset button... How is it possible?
Thx
How hard reset network settings in T6-423 ?
Re: How hard reset network settings in T6-423 ?
But, was .22 part of the existing DHCP pool? If so, you could try changing the pool settings to exclude .22 temporarily until you get it sorted.
Frustrated Beta Tester!!!
Hello, you can install the TNAS PC application in Windows to find your device. After finding the device, you can modify your IP through the webUI.
