recover data from my other nas
Yaro
France
Post by Yaro »
I'm having a lot of difficulty mounting a remote folder (smb unraid) on my terramaster. In the other direction, no problem.
I tried all possible combinations and I always get "target unavailable"
Is there a trick that I don't know or do you have another idea for transferring my data from an Unraid server to tnas?
Many thanks for your response
TMlinda
Re: recover data from my other nas
Post by TMlinda »
Yaro wrote: 01 May 2024, 13:49
You can try to put the server and TNAS device on the same network and then mount them; or you can transfer the data from the server to the local computer, and then copy the data to TNAS through SMB or FTP protocols.
Yaro
France
Post by Yaro »
thank you for your reply. The two nas are on the same network. I can access the unraid smb from my pc but I can't do it from tnas.
I have 20TB to copy, the option to use the PC will unfortunately take me too long.
I also played with smb versions 1/2/3 without success. It's quite frustrating because it's something quite basic normally.
I am with an F4-424 in 5.1.123-00529
Hope this can help: viewtopic.php?t=6093
Return to “File Services”
