TOS System Drive on M2 SSD
fdnyfish
Post by fdnyfish »
What size M2 SSD will I need if I want it to be my TOS System drive?
Where can I find instructions on setting this up?
Re: TOS System Drive on M2 SSD
Conventional capacity hard disk can be used, you can see our website compatibility list: https://www.terra-master.com/global/compatibility/
Compatibility list: viewtopic.php?t=3532&hilit=compatibility
You can refer to the installation guide video installation M.2 SSD:https://support.terra-master.com/quickg ... 424&page=1
ThanogHamros
Post by ThanogHamros »
he M.2 SSD size for your LattePanda TOS system drive depends on your needs. Here's a quick guide:
Basic Use (OS + Few Apps): 128GB - 256GB is sufficient.
Moderate Use (OS + Multiple Apps): 256GB - 512GB is a good balance.
Heavy Use (Large Games/Files): 512GB or 1TB for ample storage.
