Hi all,
I'd like to put in cron a simple script to log CPU and HDD temperatures on my F2-210 (ARM Cortex A53) using TOS 4.
I do have SSH access... I tried to search for some utility in the filesystem to do that, but failed (*)
Is there a path exposed under /proc or /sys with the temperatures?
Or some utility like lm_sensors for TOS4 ?
Thanks!
(*) I did find a /usr/bin/hddtemp utility but that fails to read HDD temperature... which however showsup just fine in the "Hardware Info" panel of TOS4...
Reading CPU and HDD temperatures from CLI
Re: Reading CPU and HDD temperatures from CLI
TOS uses the SMART tool to obtain the temperature of the hard drive. You can also manually obtain the temperature information of the hard drive through this command:
smartctl -A /dev/sd? |grep TemperatureTo contact our team, please send email to following addresses, remember to replace (at) with @:
Ok thanks! Good point!
What about the CPU? I found /sys/devices/virtual/thermal/thermal_zone0/temp but how do I convert that number to Celsius degrees?
Thanks!
Thanks!
ec_stat -rctTo contact our team, please send email to following addresses, remember to replace (at) with @:
Actually I don't have that tility ec_stat on my TNAS... where can I grab it ?
Sorry, I just noticed that you are using the F2-210 model with arm architecture.
Please use this to get CPU temperature:
cat /sys/class/thermal/thermal_zone0/temp | awk '{print ($1 / 1000) - 18}'To contact our team, please send email to following addresses, remember to replace (at) with @:
