Backup speed
The brand-new USB Copy not only provides common backup features, in order to realize offline backup and defend against threats from external networks.
rz259
Germany
Backup speed
Post by rz259 »
I am completely new to the froum and to Terramaster. I plan to buy a F2-423 or a F4-423 with initially two 4 GB disks. I'd like to backup my data using an external USB disk.
How fast is the backup via USB-disks? Currently I have only 300 GB and the volume of daily changes is not very high, but I'd like to make sure that the backup via USB is fast since the volume of data might increase in the future.
So how fast is the USB port of these machines?
And do you have a recommendation for the external usb drive?
Thanks a lot for your help,
Rudi
Re: Backup speed
For information about the rate of the USB port, you can refer to the official website's public parameter information here. It should be able to meet your requirements.
https://www.terra-master.com/us/product ... u&mid=1125
Regarding the USB disk you mentioned, do you mean a USB DAS device that can load HDD or something else?
We also sell USB DAS devices, if you need:
https://www.terra-master.com/us/product ... o-das.html
rz259
Germany
Re: Backup speed
Post by rz259 »
Thanx for your reply, the USB peed looks very promising.
Regarding the USB disk - I just need a single external disk in a case, that's all.
Regards,
Rudi
Re: Backup speed
TNAS does not have any specific requirements regarding the disk used for your USB case.
Perhaps there is any requirements for your USB case.
Return to “USB Copy”
