F4-210 RAm is full without any work
Hardfecx
Post by Hardfecx »
Hi Team,
since I installed the last Update, the Ram Memory over the day, without that the Terramaster does any Work.After a Restart it runs normal again but some Hours later it has the same Problem. The only Software installed on it is the "Usb Copy"
Re: F4-210 RAm is full without any work
Did it happen in a short period or just keep showing high like this? What version TOS running in your TNAS?
Hardfecx
Post by Hardfecx »
Yesterday I saw it after my Nas ran for 26 hours. and the Memory stays full but the Nas is doing nothing and the disks go to sleep after one hour of inactivity.
You can see the TOS version on picture 1
Now, 18 hours after a restart the memory is at 60% (picture 2) and the nas does any activity
Hardfecx
Post by Hardfecx »
Now, after 22h online, the same Problem... nothing was running, disk were asleep...
Would you sort the Memory in "Process monitor", and check which service taking so much memory?
Hardfecx
Post by Hardfecx »
Please have a look, there is not one only process wich take a lot of memory
Thank you for your information, we will look into it and come back to you soon.
Hardfecx
Post by Hardfecx »
Maybe it helps you to know that on my Nas runs a Raid5 with 4 x 2 TB Disks an one 2TB Disk connected on USB for "Backup"
Hardfecx
Post by Hardfecx »
Even after TOS 4.1.28 update, the issue is the same...
It has not been fixed in TOS4.1.28, it would be done in later version.
