I just bought the 2.5G USB-A Adaptor, because I wanted to upgrade my network to 2.5G.
The 2.5G Adaptor is listed under lsusb but I can't find it under interfaces and it doesn't request an IP over DHCP.
Does anybody know how to fix this other than going back to 5.0.176?
2.5G Adaptor TOS 5.1.67 F5-221
- crisisacting
Re: 2.5G Adaptor TOS 5.1.67 F5-221
Restart your NAS with it plugged in & it should show up on TOS after reboot.
I already rebooted several times. The adaptor is shown unter lsusb, but not in ip a nor under Network Interfaces in GUI. I also found an older post where someone had the same problem and only got it to work till 5.0.176 and that topic is locked without a solution.
viewtopic.php?p=27855
- crisisacting
Verify it works in another OS.
If it does work there, you might need to apply this to the Terra-Master 2.5 Gbps USB Ethernet adapter: viewtopic.php?f=82&t=5257&p=30301&sid=8 ... f1b#p30301
Well, I tried it on 3 Windows 11 PCs and all of them can use it and connect to the network, but non of them is able to detect the A-USBLAN-2.5G Adaptor with this Realtek tool. So I was not able to change any of the programming.crisisacting wrote: ↑03 Apr 2024, 17:32Verify it works in another OS.
I updated to TOS 5.1.123 and nothing changed. Still the TerraMaster A-USBLAN-2.5G Adaptor is not working on my NAS. I also tried on a Linux PC with Fedora 39 - no problem.
You can refer to the following link to connect it to Windows 10 for operation, and then use it on TNAS: viewtopic.php?t=5257
Ok, installed Windows 10 Pro on a Proxmox VM and with that it was possible to flash the device. With Windows11 it didn't work on 3 PCs. Now it's working.
