[ taxy ] A reverse proxy server with built-in WebUI
About: https://github.com/picoHz/taxy
Category:
Applicable models: x.64 series, ARMv8 series, ARMv8.2 series
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.37 or later versions
Applicable TOS6: 6.0.124 or later versions
App download: https://tmnascommunity.eu/download/taxy
Required packages:
TOS5 & TOS6: click on Support & Help from app description inside the App Center
About:
Overview
Built with Rust for optimal performance and safety, powered by tokio and hyper
Supports TCP, TLS, HTTP1, and HTTP2, including HTTP upgrading and WebSocket functionality
Easily deployable single binary with a built-in WebUI
Allows live configuration updates via a REST API without restarting the service
Imports TLS certificates from the GUI or can generate a self-signed certificate
Provides Let's Encrypt support (ACME v2, HTTP challenge only) for seamless certificate provisioning
Supports automatic HTTP Brotli compression
Mike2882
Singapore
Re: [ taxy ] A reverse proxy server with built-in WebUI
Post by Mike2882 »
Hello , can i seek guidance on how to configure on proxies portion?
samius
Post by samius »
Thanks, it works very quickly. But can't get acme certificate (letsencrypt). Nginx proxy manager receive cert, taxy does not.
F4-424 MAX TOS 7
Bartman
Post by Bartman »
(Access denied !) - you need to login on TOS with an admin role account
Next step please.....
F2-423
TOS 7.0.0777 (X86)
Was posted several time that the apps compatible with TOS6 > 6.0.420 will contain TOS6 on their filename.
Taxy is not yet available for TOS6 > 6.0.420
viewtopic.php?f=37&t=1482
Small hint, whenever you ask for support, is better to be a bit more detailed on your request and a screenshot will always help the support team.
Bartman
Post by Bartman »
Thank you outkastm
F2-423
TOS 7.0.0777 (X86)
TOS6 version is available now
halgory
Post by halgory »
Are you the original dev? Just checking.
The app isn't working well, and I raised issue on the Git and they told me to update the software, but the software version can't be updated for TNAS. The current release version is like a year ahead of this version.
Cheers.
samius
Post by samius »
halgory wrote: 20 Jan 2025, 04:16
If asked, you can update it by replacing the binary file in the application folder...
F4-424 MAX TOS 7
halgory
Post by halgory »
samius wrote: 21 Jan 2025, 02:57
Thanks bro, I'm only new to Linux/Unix and TOS so I'm learning. Thanks for the help :)
