can't copy to NAS some files, strange error
epiq
Post by epiq »
I faced with inability to copy certain files to TNAS F5-421. In messages log I see this:
==> /var/log/messages <==
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.396155,  0] ../source3/lib/sysquotas.c:461(sys_get_quota)
Jul  2 16:56:44 TNAS smbd_audit:   sys_path_to_bdev() failed for path [2CHECK-from-sty2/SABLIA/12400003.jpg]!
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.396304,  0] ../source3/lib/sysquotas.c:461(sys_get_quota)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.396408,  0] ../source3/lib/sysquotas.c:461(sys_get_quota)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.396510,  0] ../source3/lib/sysquotas.c:461(sys_get_quota)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.404501,  0] ../source3/lib/sysquotas.c:461(sys_get_quota)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.404669,  0] ../source3/lib/sysquotas.c:461(sys_get_quota)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.404773,  0] ../source3/lib/sysquotas.c:461(sys_get_quota)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.404873,  0] ../source3/lib/sysquotas.c:461(sys_get_quota)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.407360,  0] ../source3/modules/vfs_fruit.c:1357(ad_read_rsrc_adouble)
Jul  2 16:56:44 TNAS smbd_audit:   ad_read_rsrc_adouble: invalid AppleDouble resource 2CHECK-from-sty2/SABLIA/12400003.jpg
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.407434,  0] ../source3/modules/vfs_fruit.c:4920(fruit_fstat_rsrc_adouble)
Jul  2 16:56:44 TNAS smbd_audit:   fruit_fstat_rsrc_adouble: ad_get [2CHECK-from-sty2/SABLIA/12400003.jpg:AFP_Resource] failed [Invalid argument]
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.407694,  0] ../source3/modules/vfs_fruit.c:1357(ad_read_rsrc_adouble)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.407733,  0] ../source3/modules/vfs_fruit.c:4920(fruit_fstat_rsrc_adouble)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.408115,  0] ../source3/modules/vfs_fruit.c:1357(ad_read_rsrc_adouble)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.408156,  0] ../source3/modules/vfs_fruit.c:4920(fruit_fstat_rsrc_adouble)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.408549,  0] ../source3/modules/vfs_fruit.c:1357(ad_read_rsrc_adouble)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.408713,  0] ../source3/modules/vfs_fruit.c:1357(ad_read_rsrc_adouble)
Jul  2 16:56:44 TNAS smbd_audit: [2020/07/02 16:56:44.425148,  0] ../source3/modules/vfs_fruit.c:1357(ad_read_rsrc_adouble)
I've tested with other files - everything passing fine.
No idea why it mentioning Apple, because client is Windows 10, server on
$ uname -a
Linux TNAS 4.13.16 #270 SMP Mon Nov 25 17:12:13 CST 2019 x86_64 GNU/Linux
Intresting observation, such issue affects just some of "*.jpg|*.jpeg|*.png|*.tiff" and ".*" files - seems all of them were originally created on Apple devices, but at the moment there laying on Windows pc and I can do everything with them, expect moving to terramaster NAS volume.
Any ideas how it can be fixed?
ps: I've tried already to look for their attributes, and there are nothing worth to mention, no attributes except "archive". I've tried to unset and copy, but got the same error.
epiq
Re: can't copy to NAS some files, strange error
Post by epiq »
I've found similar bug report in Samba:
https://bugzilla.samba.org/show_bug.cgi?id=14275
maybe it's related ...
Anyway I would like to get any feedback from terramaster support.
DiscoSi
Post by DiscoSi »
epiq wrote: ↑02 Jul 2020, 23:32 I've found similar bug report in Samba:
This is a long shot but have you tried disabling AFP support and Bonjour discovery in the TNAS settings? Both are enabled by default and if you have no Apple Mac devices using it then it should be safe to disable, at least to test if it works.
epiq
Post by epiq »
Well, actually i do have Mac users with TimeMachine enabled, but just to be sure i'll try to test such workaround and update you.
HoPeY
Post by HoPeY »
Maybe unrelated but from what I've seen lately my files have been corrupt (try copying them to a new destination) or my device has needed to be reattached (USB ones (so try eject)).
epiq
Post by epiq »
DiscoSi wrote: ↑03 Jul 2020, 02:56
Disabled both AFP&Bonjour - no effect at all, same error.
i.e. it looks like those files somehow different.
Found one crazy workaround:
1.create zip archive with those files
2.move archive outside of folder there files resides
3.copy to NAS
4.extract on NAS
without step 2, step 3 also producing same error.
i.e. seem's like those .DS folders with files from Mac somehow broken, and while Windows able to handle it, Samba doesn't ...
May I know the exact current TOS version ? We have been reported for this issue in former version, while it should have been fixed now.
