New qbittorent install via App Center not running
This might be a dumb question but bear with me.
Installed qbittorent v4.1.12 via the built in App Center on TOS 5.1.123 but it won't run/start. Same thing happened with Transmission so I'm not sure what is going on here. Any help to get these even to the main webUI page so I can configure it would be good!
Re: New qbittorent install via App Center not running
Forgot to add this is on a T9-423 unit
This seems to be some kind of exception causing the startup to fail.
May I ask if you remember upgrading to TOS versions before TOS 5.123?
Please enter the following command to check a certain configuration directory and provide us with the output information:
ls -ail /etc/init.d/
df-json
The unit came with v4.something but I upgraded immediately via manual process to v5.1.64 (i think) and only then created the storage plus added in the apps etc
Outputs:
# ls -ail /etc/init.d/
total 292
229 drwxr-xr-x 3 BennyT BennyT 4096 Mar 26 10:41 .
11 drwxr-xr-x 85 BennyT BennyT 4096 Mar 26 11:14 ..
295 -rwxr-xr-x 1 BennyT BennyT 1496 Apr 24 2022 afp
298 -rwxr-xr-x 1 BennyT BennyT 2037 Apr 28 2022 avahi
306 -rwxr-xr-x 1 BennyT BennyT 1685 Jun 9 2022 cron
240 -rwxr-xr-x 1 BennyT BennyT 642 Dec 17 2021 dhcpcd
3314 lrwxrwxrwx 1 BennyT BennyT 36 Mar 13 11:47 docker -> /Volume1/@apps/docker/init.d/service
2957 lrwxrwxrwx 1 BennyT BennyT 42 Mar 13 11:47 DockerEngine -> /Volume1/@apps/DockerEngine/init.d/service
241 -rwxr-xr-x 1 BennyT BennyT 1616 Dec 17 2021 dovecot
296 -rwxr-xr-x 1 BennyT BennyT 2363 Apr 25 2022 ftp
242 -rwxr-xr-x 1 BennyT BennyT 15945 Dec 17 2021 functions
309 -rwxr-xr-x 1 BennyT BennyT 2070 Mar 13 12:00 initnet
243 -rwxr-xr-x 1 BennyT BennyT 5510 Dec 17 2021 ipsec
244 -rwxr-xr-x 1 BennyT BennyT 2478 Dec 17 2021 iptable
245 -rwxr-xr-x 1 BennyT BennyT 1825 Dec 17 2021 iscsid
326 -rwxr-xr-x 1 BennyT BennyT 1989 Mar 13 12:00 mediadb
321 -rwxr-xr-x 1 BennyT BennyT 1902 Mar 13 12:00 minidlnad
313 -rwxr-xr-x 1 BennyT BennyT 1847 Apr 19 2022 mountusb
291 -rwxr-xr-x 1 BennyT BennyT 1709 Jun 28 2022 msg
246 drwxr-xr-x 2 BennyT BennyT 4096 Mar 13 12:00 nas
325 -rwxr-xr-x 1 BennyT BennyT 2604 Jun 7 2022 nfs
260 -rwxr-xr-x 1 BennyT BennyT 3448 Mar 13 12:00 nginx
323 -rwxr-xr-x 1 BennyT BennyT 2961 Aug 31 2022 nslcd
286 -rwxr-xr-x 1 BennyT BennyT 1127 Dec 17 2021 ntp
327 -rwxr-xr-x 1 BennyT BennyT 2266 Sep 28 2022 online
287 -rwxr-xr-x 1 BennyT BennyT 1671 Dec 17 2021 open-iscsi
239 -rwxr-xr-x 1 BennyT BennyT 6105 Mar 13 12:00 ovpnc
288 -rwxr-xr-x 1 BennyT BennyT 3230 Dec 17 2021 php-fpm
314 -rwxr-xr-x 1 BennyT BennyT 1080 May 20 2022 polkit
3317 lrwxrwxrwx 1 BennyT BennyT 41 Mar 26 10:34 qbittorrent -> /Volume1/@apps/qbittorrent/init.d/service
302 -rwxr-xr-x 1 BennyT BennyT 2196 Aug 11 2022 rcK
285 -rwxr-xr-x 1 BennyT BennyT 4309 Jan 30 19:34 rcS
310 -rwxr-xr-x 1 BennyT BennyT 2749 Apr 29 2022 redis
301 -rwxr-xr-x 1 BennyT BennyT 1757 Jul 26 2022 ResourceCollection
289 -rwxr-xr-x 1 BennyT BennyT 455 Dec 17 2021 rpcbind
311 -rwxr-xr-x 1 BennyT BennyT 1315 Jun 7 2022 rsync_service
230 -rwxr-xr-x 1 BennyT BennyT 649 Dec 17 2021 S01logging
231 -rwxr-xr-x 1 BennyT BennyT 422 Dec 17 2021 S02acpid
232 -rwxr-xr-x 1 BennyT BennyT 54 Dec 17 2021 S10hotplug
233 -rwxr-xr-x 1 BennyT BennyT 1321 Dec 17 2021 S20urandom
234 -rwxr-xr-x 1 BennyT BennyT 1559 Dec 17 2021 S29netplug
305 -rwxr-xr-x 1 BennyT BennyT 1850 May 24 2022 S30dbus
235 -rwxr-xr-x 1 BennyT BennyT 453 Dec 17 2021 S30rpcbind
228 -rwxr-xr-x 1 BennyT BennyT 18038 Mar 13 12:00 S40network
316 -rwxr-xr-x 1 BennyT BennyT 2023 Aug 29 2022 S49pgsql
236 -rwxr-xr-x 1 BennyT BennyT 1190 Dec 17 2021 S80dhcp-relay
237 -rwxr-xr-x 1 BennyT BennyT 1156 Dec 17 2021 S80dhcp-server
238 -rwxr-xr-x 1 BennyT BennyT 369 Dec 17 2021 S90dcron
303 -rwxr-xr-x 1 BennyT BennyT 1398 Apr 27 2022 S99nasips
322 -rwxr-xr-x 1 BennyT BennyT 2595 Mar 13 12:00 samba
318 -rwxr-xr-x 1 BennyT BennyT 1054 Apr 19 2022 ScheduledTask
319 -rwxr-xr-x 1 BennyT BennyT 1073 May 6 2022 sftp_service
308 -rwxr-xr-x 1 BennyT BennyT 775 Sep 19 2022 smartfan
290 -rwxr-xr-x 1 BennyT BennyT 2786 Dec 17 2021 snmpd
300 -rwxr-xr-x 1 BennyT BennyT 1338 May 31 2022 ssh_service
320 -rwxr-xr-x 1 BennyT BennyT 5777 Mar 13 12:00 sssd
324 -rwxr-xr-x 1 BennyT BennyT 1490 May 6 2022 telnet_service
3291 lrwxrwxrwx 1 BennyT BennyT 40 Mar 13 11:47 TFM_Backup -> /Volume1/@apps/TFM_Backup/init.d/service
315 -rwxr-xr-x 1 BennyT BennyT 1042 Aug 1 2022 tosdaemon
292 -rwxr-xr-x 1 BennyT BennyT 2259 Sep 14 2022 udev
293 -rwxr-xr-x 1 BennyT BennyT 2119 Sep 28 2022 upnpd
297 -rwxr-xr-x 1 BennyT BennyT 525 Apr 26 2022 ups
304 -rwxr-xr-x 1 BennyT BennyT 1550 May 6 2022 webdav
299 -rwxr-xr-x 1 BennyT BennyT 5109 Mar 13 12:00 winbind
294 -rwxr-xr-x 1 BennyT BennyT 715 Apr 19 2022 wsdd
# df-json
Device Filesystem Status Total(Kb) Free(Kb) Used(Kb) Used% Mount
/dev/md9 ext4 rw 7769268 5850196 1502920 20% /
devtmpfs devtmpfs rw 12201756 12201756 0 0% /dev
proc proc rw 0 0 0 0% /proc
devpts devpts rw 0 0 0 0% /dev/pts
tmpfs tmpfs rw 12225976 12225944 32 0% /dev/shm
tmpfs tmpfs rw 12225976 12201596 24380 0% /tmp
tmpfs tmpfs rw 12225976 12225580 396 0% /run
sysfs sysfs rw 0 0 0 0% /sys
tmpfs tmpfs rw 12225976 12212732 13244 0% /opt/var
/dev/mapper/vg0-lv0 btrfs rw 93692719104 42323426324 51367936364 54% /Volume1
/dev/mapper/vg0-lv0 btrfs rw 93692719104 42323426324 51367936364 54% /home
cgroup tmpfs rw 12225976 12225976 0 0% /sys/fs/cgroup
cgroup cgroup rw 0 0 0 0% /sys/fs/cgroup/cpuset
cgroup cgroup rw 0 0 0 0% /sys/fs/cgroup/cpuacct
cgroup cgroup rw 0 0 0 0% /sys/fs/cgroup/blkio
cgroup cgroup rw 0 0 0 0% /sys/fs/cgroup/memory
cgroup cgroup rw 0 0 0 0% /sys/fs/cgroup/devices
cgroup cgroup rw 0 0 0 0% /sys/fs/cgroup/freezer
cgroup cgroup rw 0 0 0 0% /sys/fs/cgroup/net_cls
cgroup cgroup rw 0 0 0 0% /sys/fs/cgroup/perf_event
cgroup cgroup rw 0 0 0 0% /sys/fs/cgroup/hugetlb
cgroup cgroup rw 0 0 0 0% /sys/fs/cgroup/pids
cgroup cgroup rw 0 0 0 0% /sys/fs/cgroup/rdma
cgroup cgroup rw 0 0 0 0% /sys/fs/cgroup/misc
/dev/mapper/vg0-lv0 btrfs rw 93692719104 42323426324 51367936364 54% /Volume1/@apps/DockerEngine/DockerData
/dev/mapper/vg0-lv0 btrfs rw 93692719104 42323426324 51367936364 54% /Volume1/@apps/DockerEngine/DockerData/btrfs
Outputs:
total 292
# df-json
There seems to be no abnormality in this regard. Please collect a system report and provide it to the technical support email or customer service window on the official website for inspection through transmission sharing tools such as WeTransfer.
Ok my bad. Turns out it was just that my browser permissions didn't allow the qBittorent popup to work so I never saw anything happening.
Nothing to do with the NAS at all
Hi all, just got my new Terramaster NAS yesterday but I also have issues opening Qbitorrent from my TOS 5.1
All I get, after installing Qbittorent from the App Center, is 404 Not Found
nginx/1.21.0
Any help is much appriciated.
Greetings Ron
nginx/1.21.0
Greetings Ron
Thanks TMcola but that didn't help unfortunately.
Greetings Ron
Greetings Ron
