Hi!
I have reseted my NAS added 2 new disks. When i start the wizard i receive my code and won't pass to the next step.
Any clues?
F2-210 Wizard blocked
Re: F2-210 Wizard blocked
This may help you solve the issue:
viewtopic.php?t=2196
Hi
Windows 11 Pro
Tryed to connect with PUTTY with success but there's no chance with the logons. I just can't reach a solution. I don't have any data to preserve.
There's no way to create a USB PEN DISK to start it? There's a PEN in the internal USB
Should be a easy way to recover from this problems............
Thanks for the help.
- crisisacting
- Silver Member
If you bricked your unit, follow this guide @ viewtopic.php?f=76&t=696
THANKS!!! Your solution helped me to solve the problemcrisisacting wrote: ↑24 Mar 2024, 15:10If you bricked your unit, follow this guide @ viewtopic.php?f=76&t=696
BIG THANK YOU!!!
