D5-300C Raid 1
raiddisk
D5-300C Raid 1
Post by raiddisk »
I had an existing RAID 1 configuration in slot 1 and 2.
I do not need that anymore.
I have an existing drive with data and an identical one that is empty and want to use this paid as a Raid 1 configuration.
Putting the data drive in slot 1 and the empty drive in slot 2 does not enable the raid mode, instead I get two different drives.
How do I setup the Raid 1 using the existing data drive and an empty drive?
Re: D5-300C Raid 1
Hi.
The situation you envisioned is not feasible.
When you create RAID1, both hard drives will be formatted.
Return to “USB Series”
