UPnP & Bonjour
Hardfecx
UPnP & Bonjour
Post by Hardfecx »
after each restart of my F4-210, UPnP & Bonjour Services are no more enabled.
So my Windows 7 Pc can't see the Nas on the Network and even per Ip Adress it isn't available.
Why does the Nas deactivate those Services after each reboot?
Re: UPnP & Bonjour
Please advise the current TOS version.
And you can manually update to the new TOS4.1.27 to see whether it's ok : http://dl.terra-master.com/cn/TOS_A1.0_ ... 291655.bz2
Hardfecx
Re: UPnP & Bonjour
Post by Hardfecx »
For the Moment I have TOS Version 4.1.24-2005180955 on it but I will update it when I am at home and post a message here if it helped.
Thank's for the update link, but shouldn't the TerraMaster search for updates by itself?
Hardfecx
Re: UPnP & Bonjour
Post by Hardfecx »
Thank you TMSupport,
the update did his Job, the two Services stay activated now!
Thank's for your help!
Best Regards
Re: UPnP & Bonjour
Thanks for the feedback. The online update has been closed for the moment.
Return to “Network”
