TNAS Mobile 3 for iPad
Squally
Post by Squally »
Hi Guys,
is there a plan to have a iPad version of the app.
It is now really "usable" now and pitty to not be able to use the "full capacity" of the iPad Screen
Other thing with the app, I'm using a VPN SSL client to connect remotly to home, and the app is not able to connect to the NAS through the VPN event if the port are open.
Using with F4-423 on 5.1.123-00529
Re: TNAS Mobile 3 for iPad
We will verify and discuss the issue of iPad not being compatible as you mentioned
Are you using TNAS's VPN Server app regarding the VPN SSL you mentioned? Generally speaking, when your device is connected to VPN, you can access TNAS by accessing the virtual IP (which you set in the VPN Server settings). You may not have successfully set up and connected to VPN. It is recommended that you refer to this check:
viewtopic.php?t=2821
Squally
Post by Squally »
Great new to think about the iPad Version.
For the remote access, I'm using a Fortigate and SSL VPN. It was perfectly working with the previons version en TNAS Mobile and the TOS V4.X (I was thinking to go back to TOS 4 but it is not available anymore)
Perhaps we can try asking Fortigate if they can develop a dedicated Fortigate VPN app on TOS.
Ortof
France
Post by Ortof »
Hello, I'm using the app on my mobile with Wi-Fi, and it works fine. However, when I switch to VPN (WireGuard on OPNsense), I encounter the same issue. I noticed that when I'm connected to Wi-Fi outside my home with VPN enabled, I can access the app. But when Wi-Fi is disabled and I'm on 4G or 5G, I can't access the app. Not sure if that helps.
