CPU Overload But...
Larr2000
CPU Overload But...
Post by Larr2000 »
While doing library maintenance, I often get alerts saying my CPU is overload and th check it out.
When I do, here is what I see. What is going on?
Running on an iMac (10.15.5) / Catalina
Netgear Gateway C7000v2 (ethernet)
TerraMaster NAS F2-210 / TOS: 4.1.24-2005180955
PLEX version 4.36.1 / 1.19.4.2935
[email protected]
[email protected]
Re: CPU Overload But...
Hi, we have released a new version of TOS4.127, here is the update package link for your reference, http://dl.terra-master.com/cn/TOS_A1.0_ ... 291655.bz2, please manually update your TOS to the version. The CPU overload issue should have been fixed in the version.
Tricky
Post by Tricky »
TMSupport wrote: ↑01 Jul 2020, 11:30 Hi, we have released a new version of TOS4.127, here is the update package link for your reference, http://dl.terra-master.com/cn/TOS_A1.0_ ... 291655.bz2, please manually update your TOS to the version. The CPU overload issue should have been fixed in the version.
Try telling that to those of us who have updated from TOS 4.124 to 4.127 and have developed the maxed out CPU and higher RAM use!
Cant believe that you still advocate using new software when you have had multiple reports about it causing problems! :roll:
This is a new version, you should try that too. @Tricky
Tricky
Post by Tricky »
Its the new version that is causing the problem fo me and others!
The high cpu issue has been fixed in the latest TOS 4.1.27, you can download the update package and manually update your TOS.
For 210 models :
For X86 models:
http://dl.terra-master.com/cn/TOS_S2.0_ ... 301433.bz2
DiscoSi
Post by DiscoSi »
TMSupport wrote: ↑02 Jul 2020, 11:16 The high cpu issue has been fixed in the latest TOS 4.1.27, you can download the update package and manually update your TOS.
For 210 models :
For X86 models:
Do you mean that this a revised release of 4.1.27 then? In other words the first release called 4.1.27 had an issue but the version available to download now has it fixed? I see that the filename is different to the 4.1.27 update I originally downloaded which was TOS_S2.0_Update_X64_4.1.27_2006231809.bz2
DiscoSi
Post by DiscoSi »
Ah ok, I've extracted the original 4.1.27 and compared to the latest one posted above, there are some file differences so I assume this is a revised release so worth reapplying if you've had issues previously with 4.1.27!
Yes, TOS 4.1.27-2006301044 is the latest one for the moment.
Return to “System Resources”
