No, 5.1.123 is the highest version, there is no higher version. If you have these problems after updating from 5.1.67, then you need to reinstall the system.viewtopic.php?t=423
The TOS 6 Beta Is Now Available for Public Testing
Re: The TOS 6 Beta Is Now Available for Public Testing
yeah i have reinstalled the system with some help from the terramaster support. half my data was repaired half was lost.TMwuu wrote: ↑17 Mar 2024, 17:20No, 5.1.123 is the highest version, there is no higher version. If you have these problems after updating from 5.1.67, then you need to reinstall the system.viewtopic.php?t=423
the TOS 6 is not ready for public testing though that is my honest oppinion.
However i do admire the resiliance of the terramaster raid. to be able to recover from such fatal error with only 50% data loss thats quite impressive.
I reverted back to 5.1.123 but got a message saying drives 4 and 5 will be deleted, once back one line and running it's saying Raid degraded so clicked the repair but nothing seems to happen.
F-221, 5.1.123
updated ok
working well
updated ok
working well
tried from 5.1.123TMwuu wrote: ↑17 Mar 2024, 17:20No, 5.1.123 is the highest version, there is no higher version. If you have these problems after updating from 5.1.67, then you need to reinstall the system.viewtopic.php?t=423
lost half my data and raids got degraded
- Attachments
- Screenshot_20240318_041813.png (5.28 KiB) Viewed 412 times
i got preatty much same problem. once i updated to tos 6 everything just died. raids got screwed data loss and now that im back on tos 5.1.123 some of my data remains rest is gone.
- computerguru79
I have 3 TM NAS'. I updated 1 of the 3 as a test, and all seems to be well. I was on 5.1.123 prior, and everything just worked. I did get the initial bad gateway screen on reboot, but cleared browser cache and it worked fine after. So far, so good!
- computerguru79
I did have to recreate my hyper-cache raid, but that wasn't a big deal.
- crisisacting
