Google Drive Sync Speed
Gareth
Post by Gareth »
It's really, really slow to sync changes. If I make a change in Google Drive online I see the change in my Google desktop app in seconds. The NAS can take very long even half an hour. Likewise, if I add a file to the NAS it can take a long time to show up in Google Drive.
I also experienced deleting some files online and they went immediately from my desktop but never from the NAS. Eventually the NAS re-uploaded the files that it should have deleted.
My Sync mode is Bidirectional. I'm on TOS 4.1.27-2006231809 with fast internet connection, plenty of free local disk space, roughly 4GB of Google drive space and no other apps running.
Can this be made more responsive and reliable?
Gareth
Re: Google Drive Sync Speed
Post by Gareth »
This app is unusable for me. It is so slow and unreliable it is causing conflicts with other users who share the folders.
I have had to uninstall it to prevent data loss.
Are you aware of these issues? Are you planning on improving them?
You can download the update package from our website and update your TOS to the latest 4.1.27-2006301044/2006291655 to see if anything better.
Gareth
Post by Gareth »
I already have latest TOS version.
Please connect your TNAS to your computer directly via the ethernet cable, and get the transferring speed from TNAS to your computer in this way.
Gareth
Post by Gareth »
Transferring speed from TNAS to my computer is not the problem, that is quick and reliable. How can I test speed of TNAS internet connection?
I think the connection speed is good but if I can test this it will demonstrate the issue is the Google Drive app, not the connection speed.
You can install FTP client such as File Zilla or XFTP to test the network speed.
Gareth
Post by Gareth »
My network speed is fine.
The Google Drive app is faulty. Please try it for yourselves and you will see it takes many minutes to even start syncing very small changes which should be almost instant. This slow execution can cause data loss so please investigate.
Yes, we will check here.
Gareth
Post by Gareth »
I have an update available for the Google Drive app. What is the changelog please?
Return to “CloudSync”
