Cannot Set more than 43gb for Hypercache
marcexeu
Post by marcexeu »
Config:
T2-212
TOS last version 5.1.xxx
2x 1TB HDD set as RAID 1 BTRFS
1x USB SSD 240 or 1TB
I have opened this post since before i had a different problem before.
My problem now is that i am able to create the hypercache, but only at a maximum of 43gb (independent if i am using a 1tb or 240gb SSD)
Another issue is that sometimes it allows me to create a cache of even lower values (ex: 42gb, 40gb, 39gb)
I had already formated the nas, both SSD's, re-created the volume etc.. no apps are installed and/or running
Maybe i can try to create the cache via SSH, since via UI i have this issue?
Anyone has the commands?
Thank you all and regards
Re: Cannot Set more than 43gb for Hypercache
The capacity that can be used to create SSD cache is related to the available RAM capacity, please refer to:
viewtopic.php?t=3314
Compared to other RAM capacity specifications, a larger proportion of 1GB RAM capacity is used for system operation, so the actual available capacity is lower.
