F2-212 Compatibility - wifi & HDD
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
Span4us
Post by Span4us »
Hello
Looking for a F2-212 and I'd like to ask some questions
1. I got 2 unused WD DC HC510 - 0F27477 / HGST DC HC510 - HUH721010ALE600. Can I use these HDDs with F2-212?
2. What usb wi-fi will work with F2-212?
TMtina
Re: F2-212 Compatibility - wifi & HDD
Post by TMtina »
1. It is recommended that you use the hard drive in our compatibility list: https://www.terra-master.com/global/compatibility/;
2. You can use the wireless network card with Realtek8812au or 8812bu chip.
Span4us
Post by Span4us »
TMtina wrote: ↑12 Mar 2024, 18:47 1. It is recommended that you use the hard drive in our compatibility list: https://www.terra-master.com/global/compatibility/;
DC HC500 & DC HC570 are in this list. But there is no DC HC510. I'm confused a bit :D
From the type of hard drive, this is available. But we have not actually tested this series of hard drive models, so we cannot guarantee 100% availability.
Return to “Compatibility”
