Current config:
T2-212
2x 1tb HDD in raid 1 - ext4
1x 1tb SSD to be used as cache connected to the usb 3.0 port
When i try to create the hypercache using my 1tb SSD attached to the USB port it only allows me to use a random value of GB (56, 23,26,23..gb even if the disk is empty) and even if i go further with the creation of the cache it:
creates it but i cannot access my folders anymore
or
does not show up as created
can you please help me?
Thank you and regards,
M.
Cannot use Hypercache
Re: Cannot use Hypercache
{L_BUTTON_AT}marcexeu
You can first pull out the SSD and format it, and then restart the system to see if the volume is running properly. If it is running properly, please stop all applications before creating the SSD cache.
I have no apps installed, no partitions on the ssd, restarted the NAS but still have the same issue.
the only thing running was smb, i have disabled it and still have the same issue.
i have factory reseted the nas, deleted the volume and storage pools, recreated it from a scrath using traid + btrfs and still have the same issue, please help me.
i Have now:
2x 1TB HDD in Raid 1
As cache i had tried to use both a 1tb and a 240gb ssd, i cannot ever go over 43gb and most of the time when creating the cache if just does not creates it, even if it says it was done.
