Manually install common_bootloader_V5.1.47?
I have an F2-220. I corrupted the bootloader somehow. I took apart the F2-220 and took out the usb drive which I assume the bootloader resides on. I downloaded the common_bootloader_V5.1.47.img and tried to copy the image on the usb stick with etcher but its not working, I also tried using rufus but that didn't work either. I put the usb stick back in and boot but it just beeps and won't boot. What's the recommended program to use to copy the common_bootloader_V5.1.47.img to the usb drive?
- crisisacting
- Silver Member
Re: Manually install common_bootloader_V5.1.47?
Follow this to make a new initboot @ viewtopic.php?t=1455
If your goal is to use TOS5, please refer to this:viewtopic.php?t=4912
It should be noted that your F2-220 cannot be decoded on TOS5 and its performance may not meet some new applications.
