About: https://github.com/libfuse/sshfs
Category:
Applicable TOS5: 5.1.37 or later versions
Applicable TOS6: 6.0.124 or later versions
App download: https://tmnascommunity.eu/download/sshfs
Required packages:
OkmSSHD
TOS5 & TOS6: click on Support & Help from app description inside the App Center
About
SSHFS allows you to mount a remote filesystem using SFTP. Most SSH servers support and enable this SFTP access by default, so SSHFS is very simple to use - there's nothing to do on the server-side.
Development Status
SSHFS does not have any active, regular contributors, and there are a number of known issues (see the bugtracker).
The current maintainer continues to apply pull requests and makes regular releases, but unfortunately has no capacity to do any development beyond addressing high-impact issues.
How to use
sshfs [user@]hostname:[directory] mountpointAlso many ssh options can be specified (see the manual pages for sftp(1) and ssh_config(5)), including the remote port number (-oport=PORT)
To unmount the filesystem:
umount mountpoint
