/etc/tos/scripts/wget_from_online: not found
Vodka357
Post by Vodka357 »
Anyone have a resolution for this?
IrisLi
Re: /etc/tos/scripts/wget_from_online: not found
Post by IrisLi »
Can you describe in detail the problem you are experiencing?Our TOS system does not have this file or folder under that path.
Vodka357 wrote: 10 Mar 2024, 06:42 Anyone have a resolution for this?
Another Vodka, perhaps. :roll:
Vodka357
Post by Vodka357 »
TMqiky wrote: 10 Mar 2024, 19:01 Can you describe in detail the problem you are experiencing?Our TOS system does not have this file or folder under that path.
refer to this link: https://support.terra-master.com/faqs/t ... tuck_at_50
That link applies to different models (and base systems)
Vodka357
Post by Vodka357 »
Gremlin wrote: 11 Mar 2024, 01:08 That link applies to different models (and base systems)
I have a F2-220 with the exact same error.
{L_BUTTON_AT}Vodka357
Please provide a screenshot, through which you can see the relevant modules and locations.
Return to “System Update”
