F2-220 update trouble
Vodka357
Post by Vodka357 »
I'm trying to install TOS but it keeps failing at 55%. I saw a suggest fix for it but I must be able to SSH into it to execute it and I don't remember my password. I tried all the suggested defaults but they don't work. There is no reset button and no real hard rest procedure i could find. Any help would be appreciated.
Vodka357
Re: F2-220 update trouble
Post by Vodka357 »
**update**
I figured out the password and got a root@TNAS:~# prompt but there doesn't appear to be anything here. I cant change directories or do anything. is there anyway to apply the update from SSH?
crisisacting
Post by crisisacting »
What version of TOS are you coming from, as there's some conditions that have to be met for several current builds?
You can try: viewtopic.php?f=76&t=423
Vodka357
Post by Vodka357 »
crisisacting wrote: ↑09 Mar 2024, 06:51 What version of TOS are you coming from, as there's some conditions that have to be met for several current builds?
The initialization page displays J1800_V4.3 in the bottom right hand corner but i've tried every update on the download page and none of them work. They all fail at 50% or 55% and the auto download fails immediately. I'm not sure what to try next.
Vodka357 wrote: ↑09 Mar 2024, 07:37
Here, you can choose a feasible TOS version for installation:
viewtopic.php?t=921
Return to “System Update”
