[SOLVED] D6-320 NOT Connecting (Linux Mint 21)
somedudeinaz
Post by somedudeinaz »
Since apparently I can't edit the original thread...viewtopic.php?t=5824
That thread concluded that my unit was DOA and so I returned it to amazon. Well, the new unit arrived along with a new toy...
Hardware:
1) D6-320
2) USB cable (https://www.amazon.com/dp/B09VY1BN48?ps ... ct_details)
3) Powered USB Hub (https://www.amazon.com/dp/B0CB82NR5C?ps ... ct_details) - I needed a hub anyway so why not try...
4) Same USB ports used as described in original post.
test 1: D6-320 w/TM cable: Powered on, drives seen, all is well - :D
test 2: D6-320 w/3rd party usb cable: Powered on, no drives seen :( :x
test 3: D6-320 w/3rd party usb cable AND USB Hub: Powered on, drives seen, all is well - :D
test 4: D6-320 w/TM cable AND USB Hub: Powered on, drives seen, all is well - :D
The USB cable (ULT-WIIQ) I have is the full 3m length. Works fine in other applications, so this might be an edge case. Or it burns just a tad too much juice for the ASMedia chipset to handle. I may experiment with other cables in the future. I've got a bunch around here somewhere...after all it could just be the length.
Was the first unit truly broken? Probably, in that it didn't matter what USB port or cable I used. Since I didn't have the hub at the time I couldn't test it.
Thanks to the following forum users for their posts which helped me figure this out:
[at=hornseye post_id=32759 time=1706188035 user_id=8659][/at]: viewtopic.php?f=67&t=5717#p32759
[at=e6SBylizVXn4 post_id=33498 time=1709224404 user_id=8886][/at]: viewtopic.php?f=67&t=4493#p33498
And for the sake of completeness here's the dmesg log. Interestingly, the Serial Number reported by dmesg is NOT the one on the unit. Since that's the same as the SN reported with the other unit I can only assume it's the serial for something internal to my PC.
[ 4006.141748] usb 7-1.1: new high-speed USB device number 23 using xhci_hcd
[ 4006.293274] usb 7-1.1: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 0.01
[ 4006.293280] usb 7-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4006.293282] usb 7-1.1: Product: 4-Port USB 2.0 Hub
[ 4006.293283] usb 7-1.1: Manufacturer: TerraMaster
[ 4006.356752] hub 7-1.1:1.0: USB hub found
[ 4006.358129] hub 7-1.1:1.0: 4 ports detected
[ 4006.388475] usb 8-2.1: new SuperSpeed Plus Gen 2x1 USB device number 6 using xhci_hcd
[ 4006.428031] usb 8-2.1: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 0.01
[ 4006.428036] usb 8-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4006.428038] usb 8-2.1: Product: 4-Port USB 3.0 Hub
[ 4006.428040] usb 8-2.1: Manufacturer: TerraMaster
[ 4006.455495] hub 8-2.1:1.0: USB hub found
[ 4006.456888] hub 8-2.1:1.0: 4 ports detected
[ 4007.117728] usb 7-1.1.3: new high-speed USB device number 24 using xhci_hcd
[ 4007.239014] usb 7-1.1.3: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 0.01
[ 4007.239018] usb 7-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4007.239019] usb 7-1.1.3: Product: 4-Port USB 2.0 Hub
[ 4007.239020] usb 7-1.1.3: Manufacturer: TerraMaster
[ 4007.284061] hub 7-1.1.3:1.0: USB hub found
[ 4007.285278] hub 7-1.1.3:1.0: 4 ports detected
[ 4007.316122] usb 8-2.1.3: new SuperSpeed Plus Gen 2x1 USB device number 7 using xhci_hcd
[ 4007.351604] usb 8-2.1.3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 0.01
[ 4007.351609] usb 8-2.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4007.351611] usb 8-2.1.3: Product: 4-Port USB 3.0 Hub
[ 4007.351612] usb 8-2.1.3: Manufacturer: TerraMaster
[ 4007.383576] hub 8-2.1.3:1.0: USB hub found
[ 4007.384877] hub 8-2.1.3:1.0: 4 ports detected
[ 4008.086146] usb 8-2.1.3.1: new SuperSpeed Plus Gen 2x1 USB device number 8 using xhci_hcd
[ 4008.106751] usb 8-2.1.3.1: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
[ 4008.106756] usb 8-2.1.3.1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 4008.106758] usb 8-2.1.3.1: Product: TDAS
[ 4008.106760] usb 8-2.1.3.1: Manufacturer: TerraMaster
[ 4008.106761] usb 8-2.1.3.1: SerialNumber: 202302280014
[ 4008.190065] usb 8-2.1.3.2: new SuperSpeed Plus Gen 2x1 USB device number 9 using xhci_hcd
[ 4008.211459] usb 8-2.1.3.2: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
[ 4008.211464] usb 8-2.1.3.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 4008.211466] usb 8-2.1.3.2: Product: TDAS
[ 4008.211467] usb 8-2.1.3.2: Manufacturer: TerraMaster
[ 4008.211468] usb 8-2.1.3.2: SerialNumber: 202302280014
[ 4008.289780] usb 8-2.1.3.3: new SuperSpeed Plus Gen 2x1 USB device number 10 using xhci_hcd
[ 4008.310616] usb 8-2.1.3.3: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
[ 4008.310620] usb 8-2.1.3.3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 4008.310622] usb 8-2.1.3.3: Product: TDAS
[ 4008.310624] usb 8-2.1.3.3: Manufacturer: TerraMaster
[ 4008.310625] usb 8-2.1.3.3: SerialNumber: 202302280014
[ 4008.389899] usb 8-2.1.3.4: new SuperSpeed Plus Gen 2x1 USB device number 11 using xhci_hcd
[ 4008.414637] usb 8-2.1.3.4: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
[ 4008.414642] usb 8-2.1.3.4: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 4008.414644] usb 8-2.1.3.4: Product: TDAS
[ 4008.414645] usb 8-2.1.3.4: Manufacturer: TerraMaster
[ 4008.414646] usb 8-2.1.3.4: SerialNumber: 202302280014
[ 4008.437194] usbcore: registered new interface driver usb-storage
[ 4008.439004] scsi host9: uas
[ 4008.439383] scsi 9:0:0:0: Direct-Access     TerraMas TDAS             0    PQ: 0 ANSI: 6
[ 4008.439915] sd 9:0:0:0: Attached scsi generic sg5 type 0
[ 4008.440198] sd 9:0:0:0: [sde] Spinning up disk...
[ 4008.440277] scsi host10: uas
[ 4008.440608] scsi 10:0:0:0: Direct-Access     TerraMas TDAS             0    PQ: 0 ANSI: 6
[ 4008.441152] sd 10:0:0:0: Attached scsi generic sg6 type 0
[ 4008.441406] sd 10:0:0:0: [sdf] Spinning up disk...
[ 4008.441726] scsi host11: uas
[ 4008.442056] scsi 11:0:0:0: Direct-Access     TerraMas TDAS             0    PQ: 0 ANSI: 6
[ 4008.442679] sd 11:0:0:0: Attached scsi generic sg7 type 0
[ 4008.442911] sd 11:0:0:0: [sdg] Spinning up disk...
[ 4008.443865] scsi host12: uas
[ 4008.443923] usbcore: registered new interface driver uas
[ 4008.444196] scsi 12:0:0:0: Direct-Access     TerraMas TDAS             0    PQ: 0 ANSI: 6
[ 4008.444652] scsi 12:0:0:0: Attached scsi generic sg8 type 0
[ 4008.444906] sd 12:0:0:0: [sdh] Spinning up disk...
[ 4009.462062] .
[ 4009.462062] .
[ 4009.462063] .
[ 4009.462073] .
[ 4010.485662] .
[ 4010.485687] .
[ 4010.485692] .
[ 4010.485809] .
[ 4011.509646] .
[ 4011.509657] .
[ 4011.509672] .
[ 4011.509715] ..
[ 4012.534002] .
[ 4012.534002] .
[ 4012.534002] .
[ 4013.557642] .
[ 4013.557665] .
[ 4013.558067] .
[ 4013.558072] .
[ 4013.558102] ready
[ 4013.558158] ready
[ 4014.469660] sd 11:0:0:0: [sdg] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 4014.469775] sd 11:0:0:0: [sdg] Write Protect is off
[ 4014.469777] sd 11:0:0:0: [sdg] Mode Sense: 43 00 00 00
[ 4014.469935] sd 11:0:0:0: [sdg] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4014.470174] sd 11:0:0:0: [sdg] Optimal transfer size 33553920 bytes
[ 4014.478842] sd 10:0:0:0: [sdf] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 4014.478974] sd 10:0:0:0: [sdf] Write Protect is off
[ 4014.478977] sd 10:0:0:0: [sdf] Mode Sense: 43 00 00 00
[ 4014.479135] sd 10:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4014.479372] sd 10:0:0:0: [sdf] Optimal transfer size 33553920 bytes
[ 4014.490798]  sdg: sdg1
[ 4014.491605] sd 11:0:0:0: [sdg] Attached SCSI disk
[ 4014.502792]  sdf:
[ 4014.503537] sd 10:0:0:0: [sdf] Attached SCSI disk
[ 4014.581631] .
[ 4014.581726] .
[ 4014.581933] ready
[ 4014.721181] sd 12:0:0:0: [sdh] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 4014.721259] sd 12:0:0:0: [sdh] Write Protect is off
[ 4014.721261] sd 12:0:0:0: [sdh] Mode Sense: 43 00 00 00
[ 4014.721416] sd 12:0:0:0: [sdh] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4014.721655] sd 12:0:0:0: [sdh] Optimal transfer size 33553920 bytes
[ 4014.746372]  sdh: sdh1
[ 4014.747492] sd 12:0:0:0: [sdh] Attached SCSI disk
[ 4015.606020] .ready
[ 4015.628457] sd 9:0:0:0: [sde] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 4015.628462] sd 9:0:0:0: [sde] 4096-byte physical blocks
[ 4015.628579] sd 9:0:0:0: [sde] Write Protect is off
[ 4015.628581] sd 9:0:0:0: [sde] Mode Sense: 43 00 00 00
[ 4015.628738] sd 9:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4015.628976] sd 9:0:0:0: [sde] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[ 4015.664274]  sde: sde1 sde2
[ 4015.665364] sd 9:0:0:0: [sde] Attached SCSI disk
[ 4016.107151] ntfs3: Max link count 4000
[ 4016.107153] ntfs3: Enabled Linux POSIX ACLs support
[ 4016.107153] ntfs3: Read-only LZX/Xpress compression included
[ 4016.107337] ntfs3: Unknown parameter 'windows_names'
[ 4016.161519] EXT4-fs (sde2): mounted filesystem with ordered data mode. Opts: errors=remount-ro. Quota mode: none.
[ 4016.419415] EXT4-fs (sdh1): mounted filesystem with ordered data mode. Opts: errors=remount-ro. Quota mode: none.
somedudeinaz
Re: [SOLVED] D6-320 NOT Connecting (Linux Mint 21)
I'm sorry. I have NO idea why it's formatted this way...
Admin? Can we go in and edit our posts?
crisisacting
Post by crisisacting »
{L_BUTTON_AT}somedudeinaz
As soon as you @ another user, formatting goes haywire.
It's always been an issue on this forum & its forum solution (phpbb).
somedudeinaz
crisisacting wrote: 03 Mar 2024, 22:44
That explains it. Thanks. I'll post a cleaned up version in a minute then
somedudeinaz
Cleaned up formatting. . .
Hardware:
1) D6-320
3) Powered USB Hub (https://www.amazon.com/dp/B0CB82NR5C?ps ... ct_details) - I needed another hub anyway so why not try...
Was the first unit truly broken? Probably, given that it didn't matter what USB port or cable I used. Since I didn't have the hub at the time I couldn't test it.
hornseye: viewtopic.php?f=67&t=5717#p32759
e6SBylizVXn4: viewtopic.php?f=67&t=4493#p33498
[ 4009.462062] .
[ 4009.462062] .
[ 4009.462063] .
[ 4009.462073] .
[ 4010.485662] .
[ 4010.485687] .
[ 4010.485692] .
[ 4010.485809] .
[ 4011.509646] .
[ 4011.509657] .
[ 4011.509672] .
[ 4011.509715] ..
[ 4012.534002] .
[ 4012.534002] .
[ 4012.534002] .
[ 4013.557642] .
[ 4013.557665] .
[ 4013.558067] .
[ 4013.558072] .
[ 4014.502792]  sdf:
[ 4014.581631] .
[ 4014.581726] .
hornseye
Post by hornseye »
@somedudeinaz - Glad my little post helped you solve your issue :D
e6SBylizVXn4
Post by e6SBylizVXn4 »
Same, and to add for me the powered usb works with the provided TM cable, I've not tried it with any other cables
Return to “USB Series”
